Home Forums Bug Reports Different Results between calculations in ‘Equation’ and ‘Diagram’
  • #2976
    Stanimir
    Dear Qucsstudio Supporter,
    The goal of attached schematic is to calculate NF of FET  under different source impedance. Do do so, the different impedance is added as a small circuit that is port terminated and equation based output variable is created that represents needed ‘generalized NF ‘. The calculated value differs depending on where the equation is placed, in the Equation component or Diagram properties. The most likely reason is not accurate interpretation of expressions containing NFmin, namely  10^(NFmin/10) by Equation component. The expression in Diagram properties works fine. In the schematic file you can find comparison for debugging.
    Best regards,
    Stanimir.
    #2978
    Stanimir
    Sorry, Attached s2p file was not permitted for security reasons. here is archived version.
    #2985
    Yes, you are right, this is a bug! Thanks a lot for reporting it. I will fix it.
