Home Forums Bug Reports documentation optimization algorithms
  • #6917
    the supported algos are:
    • grid search
    • steepest descent
    • Nelder-Mead
    • DEGL/SAW
    • DE/current-to-pbest/1/bin
    • DE/best-of-rand/2/bin
    • DE/best/1/bin
    • DE/rand/1/bin
    The order in the GUI is different from the order in technical.pdf. Is there a reason?
    steepest descent is not described in technical.pdf.
    What does the “/bin” mean? There is no explanation in technical.pdf
    “grid search” offers a parameter “Maximum number of iterations”. What does it do? Its not mentioned in technical.pdf
    Parameters in general: Probably sensible to check, that all of them are documented in technical.pdf
    #6924
    Ah, I saw there is a text in the F1 help. I suspect some of my questions are still valid.
