Home Forums Usage Library is Corrupt problem
  • #580
    tomhajjar
    Been using QucsStudio 2.5.7 for a long time. It is in a directory named “QucsStudio”. Copied QucsStudio 3.3.2 folders into a new directory called “QucsStudio – 3.3.2”. I’m getting “Library is Corrupt” errors if I try to load any of the libraries.
    #581
    tomhajjar
    QucsStudio 2.5.7 didn’t care if “Qucs” and “QucsStudio” User libraries were in C:\Users\…\.qucs\user_lib.
    On startup you got one “Library is Corrupt” message and the “native” QucsStudio libraries are available.
    QucsStudio 3.3.2 On startup however gives a “Library is Corrupt” message and then doesn’t load the “user” or “native” QucsStudio libraries.
    Is there a reason for this change?
    P.S.
    “Notify me of follow-up replies via email” check box is inoperative
    #604
    ddieterle
    Hi Tomhajjar,
    the “Notify me of follow-up replies via email” works only if another member is replying to your post. If you reply to your post yourself no notification is fired.
    For the library topic, I’m sorry. I’m the wrong person to help you out there. Hopefully some other person can help you soon.
    Best regards
    Daniel.
    #606
    tomhajjar
    Thanks for the response. I can’t be the only one using both Qucs and QucsStudio. I have hundreds of old simulations in both and having to manually edit the files in a text editor to convert them is a pain especially if a matching model or component doesn’t exist.
    It would be nice to be able to change the default location of the files/libraries so there won’t be conflicts.
