Home Forums Usage Locking two or more quantities so they vary together during tuning
  • #7094
    cfant
      This is my very first post in this forum.  I did search the posts here before posting this, so I am reasonably certain I am not duplicating an earlier question.
      Say I have an RF path with a transmission line Tee and a line connected to each of the three arms of the Tee.  If I want to tune the width of each line, I must also tune the width of the arm of the Tee the line is connected to.  That is, when tuning, I need to vary two different quantities in step, since they must be equal.  How can I do that?  Can tuning be done on quantities defined parametrically?
      FYI, I am running QucsStudio on Linux via WINE, but that should not affect my question.  Keep up the good work!
      #7097
        greetings to another wine user.
        you can define a parameter in an equation and use the Tuning-Tool on that.
