Qucs has a few Verilog-A PIN diode projects. You can also convert some Aplac or Spice PIN models into sub-circuits. How to get the parameters for a real life diode is problematic.
You can also model the diode as only two states, ON/OFF with Cp, Ls and Rs. That will be the easiest to do since the parameters can be found on the data sheet.
