Home Forums Usage Temperature sweep!
  • #7382
    AshMadni
    I have designed a very simple bandgap reference with a startup circuit. I was wondering if anyone knows how to do a temperature sweep. I have attached the bandgap circuit for your interest
    Best wishes,
    Ash
    #7497
    Enki
    Every component except for OP1 in your sch has a parameter called “Temp”. You can create a variable to change the operating temperature by tunig, sweep or optimization. I´ve never use it, so I don´t know which is the performance will be affected.
