Home Forums Bug Reports Can not move marker on S parameter schematic.
  • #7055
    stevegeers
      I placed a maker on a graph on an s-parameter schematic. Very rarely can I drag the marker across the trace. I keep selecting either the maker info callout or the entire graph.
      #7060
        see video attached.
        #7061
          My file uploads were restricted for security reasons, I try again as archive
          #7078
          stevegeers
            Today, all the markers moved easily. Yesterday, I had to try to drag the maker all the way across the screen and then it would move.
            #7087
              ignore my last 2 posts.
              Thanks to you, I found out that it is possible to drag ‘n’ drop the marker directly.
              In my installation, it works fine.
              remember: In qucs, selection of overlayed items (e.g. a diagram and a “marker info callout”) works as follow:
              A) none of the items is selected yet: mouse click selects top most item
              B) one of the items is already selected: mouse click selects next item.
              What happens to me regularly:
              – diagram is selected
              – I want to move the “marker info callout” and try to drag’n’ drop it somewhere (but forgot, that the diagram is still selected).
              -> diagram is moved instead of marker box.
