Home Forums Installation Corrupt Library
  • #759
    smaddy4123
      I am installing this on a PC running Windows 7 Professional and when I run the program I get an error message saying “The Library is Corrupt”.  I can click OK and the program starts and seems to run correctly except that if I select a library it shows the components for the library a line above the one selected.  If I try to create my own library it does not appear in the list.  I have tried downloading the program again but still get the same message.
      I have been a long time user of QUCS and would like to move to QUCS Studio but I use a lot of my own library and this prevents me from making the transition.
      Any help would be appreciated.
      #762
        I have no idea where this come from. I’ve successfully tested QucsStudio 3.3.2 on Windows 7.
        Perhaps have you an old user library in the ~\.qucs\user_lib\ directory?
        Can you check if the QucsStudio\library\ directory contains reasonable files? Or maybe, do they contain wrong (Windows style) linefeeds, i.e. 0A & 0D instead of 0A only?
        #764
        smaddy4123
          Thanks for your rely.  Yes I did have an old library in this directory from my old QUCS installation.  This also was fixed by specifying a different directory where projects are saved, on the command line.
          I maintain the old QUCS program since there doesn’t seem to be any way to convert a QUCS file to a QUCS Studio format
          Thanks for the excellent program!
          #785
            Does this mean that the problem with the corrupt library is fixed now? Or does it still happen?
            #787
            smaddy4123
              Yes it is fixed.
              Thanks
