Home Forums Tools Differential S-Parameter Port
  • #7412
    AntoC
      I need to optimize the components of a matching and tuning circuitry attached to a multi-channel coil. In ADS, it was possible to use differential S-parameter ports. How could I do that in QucsStudio?
      #7723
        Hi AntoC,
        for S-param simulations, you would use a “power source”. That has 2 ‘pins’, so it is already differential. Or do you mean the S-param-Block for a touchstone file?
        Cheers
        PS: are you working on an MRI RF coil?
