Home Forums Bug Reports equation based Monte Carlo
  • #934
    zhongche
    There is an example (simulation_MonteCarlo.qucs) from the documention that one can define a  parameter with a distribution in an equation.  That doesn’t seem to work, even for the example provided.  In the filter design example, “cap” only takes on the nominal value without any distributions.  This can be easily verified by making “cap” the only parameter with a tolerance. The output contains one trace, not an array of traces as one would expected.
