Home › Forums › Bug Reports › equation underscore subscript This topic has 1 reply, 2 voices, and was last updated 4 years, 7 months ago by MicrowaveMax. Viewing 2 posts - 1 through 2 (of 2 total) Author Posts 4. May 2021 at 18:13 #922 paultParticipant It seems that sometimes depending on the export setting the _ symbol results in the equations subscripting and then they dont work. This topic was modified 1 year, 7 months ago by maelh. Reason: Convert all remaining http links to https links 31. May 2021 at 11:17 #940 MicrowaveMaxParticipant Hi, This happens if Export is set to GUIonly. Author Posts Viewing 2 posts - 1 through 2 (of 2 total) You must be logged in to reply to this topic.
