Home Forums Usage Access to frequency value in S-Parameter Sweep
  • #8893
    Mar70
      I would like to use the current frequency value of S-parameter sweep for frequency dependant variable in equation.
      So the assigned parameter should change with frequency according to formula.
      Is there a way to do this?
      With best regards
      #8895
        In the “Equation defined component in frequency domain”, the variable ‘freq’ is defined. So you can do things like this (equals a 10nH inductor)
        But ‘freq’ is not defined in equation blocks.
        #8980
        Vincent
          Like this?
          The external variable “f” in “Equation” is equal to the internal variable “frequency” in the S-parameter simulation.
          This allows us to calculate the impedance via S11: = mag(50*(1+S[1,1])/(1-S[1,1])) with respect to the internal variable “frequency” and also the theoretical impedance 2*pi*f*L where the variable “f” is the image of the internal variable “frequency”.
