I’m looking at optimizing a PI Pad network similar to the attached diagram. I would like to find a balance between power dissipated in the resistors and return loss. I’ve tried using wire labels as well as voltage and current probes to collect the required information; however, none of it ever seems to produce results – i.e. I can’t use them in an equation or plot them in a graph.
Does anyone have any suggestions on ways to achieve my goal or thoughts on mistakes I may have made?
Thanks!
This topic was modified 1 year, 10 months ago by
