Home Forums Usage EM-simulation result to sNp-file ?
  • This topic has 2 replies, 3 voices, and was last updated 1 year ago by JGG.
  • #8837
    SM6PGP
      First of all – Thank you very much for this new release 5.8 of  uSimmics.
      I am really enjoying all new features and possibilities.
      The EM (ftdt) simulation has taken a large step forward now when it is possible to have more than 2 ports, thinking of power splitters 90 deg hybrids etc..
      I tried to export the result from the EM-simulation to a sNp-file but the  *.dat file generated from the EM-simulation does not seem to be compatible with the sNp-file export.
      ” no s-parameters found in input file
      Converter ended with errors! “
      The data is there and can be viewed in the diagrams but I would like to import the result into another schematic.
      What am I missing ? or is it a bug (then this posting belongs in the bugs topic)
      Is there some workaround possible ?  (S11) => S[1,1] , (S21) …..
      Hannes – SM6PGP
      #8882
        Currently, the EM simulation calculates the first row of s-parameter matrix only, because each row would mean a new, time-consuming simulation (due to FDTD). Therefore, a conversion into sNp file is not possible. Sorry for this!
        #8912
        JGG
          For reciprocal designs, its easy to create a 2 port 4 S paramter file in a spreadsheet oans store a s a Touchstone file
