Home › Forums › Tools › Frame (Document Settings) This topic has 0 replies, 1 voice, and was last updated 4 years, 7 months ago by rmd. Viewing 1 post (of 1 total) Author Posts 30. August 2021 at 17:53 #1023 rmdParticipant Greetings. A frame is installed for a particular schematic: > File > Document Settings > Frame > DIN A3 landscape Often, an event (such as saving the document, or making a change within the document) changes the frame. The frame will then reset to DIN A5 landscape. How can the frame be set to a particular value…? Thank you in advance. Author Posts Viewing 1 post (of 1 total) You must be logged in to reply to this topic.
