- This topic has 2 replies, 2 voices, and was last updated 3 years, 2 months ago by
Enki.
22. November 2022 at 15:09 #6800
In my project I want to run the netlist of a pcb layout simulation from Matlab/Octave. Is there a way to do it?
For now, I am able to generate and simulate sch netlist from matlab without any issue. However, the netlist format for pcb layout and EM simulations seems to be different. Can I use Qucssim.exe for that or qucsfdtd.exe? How?
Anyhelp is more than welcome. Once I got it running I’ll post the code for the benefit of the QucsStudio community.
Thanks!
This topic was modified 3 years, 2 months ago by
Enki.
23. November 2022 at 18:45 #6803Hi,
did you solve the problem in the meanwhile?
I’m unfamiliar with the qs em simulation. It could help, if you setup a very minimalistic example that shows your problem. You can package the qs project with Project -> create package and upload the file here.
24. November 2022 at 12:43 #6808Hi Carsten,
I wanted to try the QucsStudio EM capabilites with a simple design: end-coupled half-wavelength bandpass filter. One of the task I want to perform for the filter design is to model the gaps between the resonators to calculate their length and link it to the lowpass prototype.
How?
I created a simple pcb layout with two copper strips and a gap separating both of them. After that, I need to change the gap width, take the s-parameters from the simulation, extract the capacitor pi-model and create a table that relates the lowpass admittance inverters with the EM simulation.
I also need to do a de-embbeding for a more accurate modelling.
By been able to manipulate the layout and run the EM simulation I could automate the process with a matlab/octave script.
What did I get?
I got it with the .sch and TL components but I want a more accurate simulations with the EM option.
What I can’t do?
- De-embedding
- Run the netlist file from a pcb layout using a Matlab/octave script
I’ve included the project with the schematic and layout. You can generate the netlist from both and see they have different formats. When I try to launch a simulation with qucssim.exe it does not work. I believe I could do it by calling qucsfdtd.exe but I don’t know how. I guess that the right person to answer that is Michael Margraf.
