Home Forums Usage How create a library (or user library) of sNp-files ?
Viewing 10 posts - 1 through 10 (of 10 total)
  • #2923
    SM6PGP
      Hi !
      I am searching for info about how to create a library of sNp-files ?
      It is a new feature of 4.2.2, but how ?
      What is the syntax of the file I should create, where do I place it and add it ?
      73 – Hannes -SM6PGP
      #2924
        In the main menu “Project” choose “Import Library…”, then select the files and enter a name for the new library. Finally, press “Convert” button.
        That’s all, good luck!
        #2925
        SM6PGP
          Thanks !
          Very nice function, I imported some ATC-cap s2p-files to try, simulation is ok
          …but when I imported the files, I did choose “capacitor” as symbol but the symbol is still the ordinary square box.
          Even if I choose “edit” i the library view and change from “none” to capacitor it does not change.
          I can only change the symbol it by editing in the “Edit Component Properties” window in a schematic.
          73 – Hannes – SM6PGP
          #2926
            Yes, the symbol combobox is currently for SPICE subcircuits only. You should not use it for sNp files.
            As a workaround, you can choose “edit” and in the “model” field append the following line:
            “polar” 0 “linear” 0 “open” 0 “none” 0 “capacitor” 0
            Note: The first character in the line above is a space!
            #2927
            SM6PGP
              OK,  I tried the workaround, it works !
              The workaround line for other component types/symbols ?
              I really like that I can se the sNp-file comment text directly in the component window, this is a really nice feature!
              #2929
                Fine!
                For other components, the keyword “capacitor” in the above-mentioned line can be replaced by “coil”, “BJT” or “FET”.
                #2931
                SM6PGP
                  Thanks !
                  It works now !
                  I made a quick trial before asking but made an error – I replaced “capacitor” with “inductor” which of course does not work !
                  #2940
                  ddieterle
                    The library creation from a set of s-parameter files is a really nice feature I was looking for so long…! 🙂
                    Is it also possible to show the component name or, if this is not feasable, the component description in the schematic?
                    You can set the file-name. This works too, but is not as readable as it would be the component name itself.
                    Thanks you,
                    Daniel.
                    • This reply was modified 4 years, 1 month ago by ddieterle.
                    #2942
                      Currently, the only possibility is to use the component name of the symbol. I.e. for the example above:
                      In the “model” field, replace the second token “SP” with “_15SQ47N_”.
                      Note that a component name must not begin with a digit, therefore the underscore at the beginning. And the schematic editor will append a number at the end in order to make the string unique, therefore the underscore at the end (for better readability).
                      Good luck!
                      #2944
                      ddieterle
                        Fine, the work around does the job. Now the component name is shown as the reference designator and incremented when drag-n-drop a new component from the library window:
                        As you can see compared to the old the new component description is much more easier to read:
                        If there is some spare time left: Might it be possible to set the two points (Bugfix: symbol combobox for sNp symbols. New feature: Reference designator as a new component property, instead of using the component name as a reference designator) on a remarks list, so that if there are changes made in the future they would be incorporated?
                        Thanks a lot for your non-exhaustive commitment,
                        Daniel.
