Home Forums Usage How do I do a simulation for this circuit ?
  • #9160
    Phloks
      Please have a look at below schematic. I have built it in real life, and the result is what is expected. Low at the input gives +12V at label RX_12V. High at the input gives 0V at label RX_12V.
      However, when I try to simulate the circuit I do not see the expected output. The output stays at around +12V no matter what the input is.
      Can anyone please tell me how I should do a DC simulation for this schematic ?
      I have tried a transient simulation with a pulse voltage source (from 0 to 3.3v, pulse length 1 second, rise and fall 1 nanosecond) which gives me a fairly constant output of +12V at RX_12V.
      A DC simulation does not give me any output in the graphics at all…..
      #9161
      Phloks
        P.S.
        With input I mean ENABLE_TX_12V.
        #9162
        w5eeg
          I think the only problem is the output MOSFET needs to be reversed so that the P-channel source is connected to the 12 volt supply.  Attaching a uSimmics schematic screenshot.
          #9164
          w5eeg
            My mistake, Q2 looks correct, and I had not included Q4. When included, there is the problem you described.
            #9165
            w5eeg
              Maybe R10 is the problem?  I have deactivated it in the attached screenshot.
