Home › Forums › Bug Reports › Inductance Loss Uncheck did not work Tagged: checkbox serial resistor This topic has 1 reply, 1 voice, and was last updated 1 year, 4 months ago by df8ca. Viewing 2 posts - 1 through 2 (of 2 total) Author Posts 28. September 2024 at 18:53 #8657 df8caParticipant When I implement loss in an inductor (series resistor / Serienwiderstand) and check the checkbox to switch it on, it works perfect. When I uncheck the checkbox, the loss stays on in the simulation. If I set it to 0 Ohm, it becomes lossless. 28. September 2024 at 19:02 #8658 df8caParticipant Solved. Reading the explanation helps. The checkbox just switches the display on and off, not the paramater. To switch the loss off, it has to be set manually to 0 Ohm. Author Posts Viewing 2 posts - 1 through 2 (of 2 total) You must be logged in to reply to this topic.
