Home Forums Bug Reports jumps in S11 with phase shifter=0
  • #7012
      Discontinouities appear when using the phase shifter component in this schematic:
      They disappear with other values for ‘phi’ or if the phase shifter is ‘shorted’
      • This topic was modified 1 year, 10 months ago by maelh. Reason: Convert all remaining http links to https links
      #7024
        Uops, yes, it’s because of a pole in the y-parameters of the phaseshifter. I will change this.
        By the way, thank you very much for all your bug reports and hints! They are very important to evolve QucsStudio.
        #7025
          Gladly
