Home Forums Bug Reports mosfet settings in opt-examples – inverter.sch
  • #6845
      The “channel width” in this example is set to 0.0001 m = 0.1 mm
      I’m not so familiar with transistors, but 1 µm (as in the standard settings) seems more realistic.
      • This topic was modified 1 year, 10 months ago by maelh. Reason: Convert all remaining http links to https links
      #6849
        That’s true! This is not a realistic example at all, but just a demo.
        If anyone can share a real-life example here, this would be great!
