Home Forums Bug Reports PCB layout creation cannot cope with microstrip elements defined in equations
  • #8500
    afrb2
      I usually use w50 for width of 50 ohm microstrip to avoid massive editing when changing substrate. but when trying to create a PCB layout from schematic this results in 0 width tracks. Going back and manually editing all the widths to a numeric value fixes things.  If one is slightly careless doing this then the Qucs studio hangs on selecting
      #8525
        Yes, you’re right. Using variables here is not yet implemented, but it will be in the coming release.
        #9170
        owkmann
          How is this going? Can we expect variables soon?
          Great simulator, thank you!
          #9171
            Indeed, I’m currently thinking about the date for a new release. But I don’t know if it will come this year.
