Home Forums Bug Reports Possibilly, a bug in the log10(x) function
  • #2993
    pu5frs
      Dear Qucstudio developer,
      Thank you very much for keeping this software available and up to date.
      I believe there is a problem with the log10(x) function for values  of x in the range [0,1]. The output is positive rather than negative as expected. The function dB(x) does well.  Below is an image for a better understanding.
      Thanks
      PU5FRS
      Circuit for debug
      • This topic was modified 1 year, 11 months ago by maelh. Reason: Convert all remaining http links to https links
      #2999
        Because s-parameters are complex-valued, log10(…) gives a complex number, too.  In rectangular diagrams, the magnitude is shown, which is always positive.
        20*log10(abs(S[3,3])) is what you want.
        #3035
        pu5frs
          Thanks.
