Home Forums Bug Reports Power Source has wrong Power
  • #2990
    Juanito
      There is a wrong setting in the Power Source. If I set it to 30 dbm (1W) and then I load it with 50 ohm, the Power over this Load is 2W !!!
      • This topic was modified 1 year, 11 months ago by maelh. Reason: Convert all remaining http links to https links
      #2992
      pu5frs
        You are just using the wrong equation for the power.
        Use Vout^2/(2R), since Vout is the peak value of the signal.
        PU5FRS
