Home Forums Bug Reports Qucs 4.3.1 just crashes (closes no warning) on Project Open
Viewing 10 posts - 1 through 10 (of 10 total)
  • #7045
    lbengineer
      As per title – Qucs 431 just crashes (closes when I try to open an existing project
      Qucs 332 works.
      There are about 30 sch files and a bunch of other things there.
      #7046
        Could you provide one of the “evil” 😉 schematics?
        If you start qs from the command line, is there a message after the crash?
        #7047
        lbengineer
          running qucs.exe from the command line does not show anything on crash (Is there a verbose / debug flag?)
          The directory has a lot of files (maybe a few from qucs-3.3). There is some proprietary stuff so I can’t easily share.
          But I think there is some more significant problem – because just creating a project – no files in c:/users/username/.qucs/test2_prj
          and opening it causes the immediate crash of QS.
          Opening a couple of the files are fine – it’s when I open Project that QucsStudio crashes.
          It crashes even with an empty project htat I
          #7048
            That sounds tough. I didn’t had similar problems. Probably only Michael can help.
            What windows version are you using? e.g. win10 Pro ?H? Maybe that’s a useful info for Michael.
            Could you try to move the complete qs program folder to another pc and try it there?
            You could also try it with an “empty” .qucs folder (just rename .qucs into .qucs_old and create a new empty .qucs folder)
            If that helps, you can populate the .qucs folder with the stuff from .qucs_old step by step and see when it fails
            #7130
            gazz
              I’m seeing something similar. Since I was forced to upgrade from win8.1 to win10 opening a project folder causes a windows pop up and Qucs 4.3.1 exits
              #7195
              rosti75
                Qucs opens a project without crashing only when the project is located in the default folder .qucs.
                If I open a project in another location, it crashes.
                It crashed both in Windows 10 and Windows 11.
                #7199
                rosti75
                  Hello. I right-clicked on the qucs.exe and ran “Troubleshoot Compatibility”. It is compatible with Windows 8. I saved the setting. Now when I start it and open a project, it doesn’t crash.
                  #7296
                  gazz
                    Thanks, running in windows 8 compatibilty worked for me
                    • This reply was modified 2 years, 11 months ago by gazz.
                    #7479
                    I have been forced to use Windows 11 and I cannot open a project from the .qucs directory without a segmentation fault.  I have been looking to see how to increase the stack size for applications running on Windows 11 but I haven’t had much luck so far.  I look forward to hearing from anyone with any ideas?
                    #7504
                    Anonymous
                      There is an easy workaround for this:
                      Close QucsStudio > Open QucsStudio > from the “Projects” pane, doubleclick on the project you want to open.
