Home › Forums › Usage › Set ‘current’ Parameter Tuning Value Manually in Dialog Box This topic has 1 reply, 2 voices, and was last updated 1 year, 5 months ago by SM6PGP. Viewing 2 posts - 1 through 2 (of 2 total) Author Posts 27. October 2024 at 23:54 #8694 owkmannParticipant Is there a way to manually set the current value in the Parameter Tuning Dialog Box? Or is there a way to set or change the increment value of the slider? Attachments:Parameter-Tune-Dialog-Box.png 28. October 2024 at 8:17 #8696 SM6PGPParticipant you can set maximum and minium values by clicking and typing in the values you want, then you can get a the tuning smoother. If you close the tuning box the setting of min/max are lost – it would be an improvement to be able to save those settings in some way. /Hannes – SM6PGP Author Posts Viewing 2 posts - 1 through 2 (of 2 total) You must be logged in to reply to this topic.
