- This topic has 10 replies, 2 voices, and was last updated 8 months, 2 weeks ago by
SM6PGP.
1. July 2025 at 2:03 #8993
I have a twin-t 800 Hz oscillator that I want to simulate and see start up and oscillation. What I see/get on the output graph is the operating voltage of 9 V with the output voltage showing a blip, as if it is trying to oscillate, but goes to a 3.5 V DC steady line. I don’t know how it goes to a DC level as the output is taken after a 100 uF coupling capacitor. How do I properly setup and analyse this circuit?
1. July 2025 at 22:46 #8995Okay all you good people, no response to my inquiry. Here is some more anomalous stuff I am getting. From the “Errors and Warnings:” box. Warning in ‘TR1’: Inserting 1 GOhm (should be Gohm) at node “_*” because it’s floating. What is this message trying to say? TR1 is the Transient box. There are no connections! What do I have to do to set this up correctly?
7. July 2025 at 8:51 #8997Hello LarryJoy !
You did not attach a schematic, but I suggest you look at page 200+ in Gunthard Kraus, QucsStudio Tutorial, version 1.6, its about oscillators.
…from the tutorial “An oscillator simulation needs a “startup push” and this is done by programing the supply voltage as a ramp signal.” – did you use that ?
Attached a pdf of a simulation of a twin-T 800 Hz oscillator
/Hannes
8. July 2025 at 2:34 #8999SM6PGP, Thank you for your response. How do I get to “Gunthard Kraus, QucsStudio Tutorial, version 1.6?” as I would like to read the information. I tried an online search but that was useless. What I did find was small print and no way to enlarge, I would have to use a magnifying glass–no good. I went to the main page for QucsStudio, there was a Technical article but no example circuits in the transient section. More help please.
–73 de WN8P
8. July 2025 at 8:16 #9000Hi !
try this
https://www.gunthard-kraus.de/qucsstudio/index_english_qucsstudio.html
or his startpage
There is a lot of useful information, his homepage is still around, unfortunately he is SK (DG8GB)
73 – Hannes – SM6PGP
8. July 2025 at 21:24 #9001Okay, we are getting closer but still no cigar. I found the “file based voltage” source and now need to know how to setup the file. Where to set up the file and how to link it to the file based voltage source. Seems like should be able to setup the information directly in the schematic somewhere next to the source? More help needed. Thanks.
–73 de WN8P, Larry
9. July 2025 at 18:47 #9003Hello again !
OK
from page 201 in the Tutorial
“An important detail is the (red marked) power supply:
ramp signal.
Vdd starts at time t = zero with a value of zero Volts and stays so up to 10 μs.From t = 10μs to t = 20μs the
amplitude rises linearly up to +12 V and stays afterwards on this value.
Therefore a “ramp.csv” file (= comma separated value file) must be written to use a “data based voltage
source” (= PWL source = piecewise linear voltage source). This file must be saved in your actual
oscillator project folder:
0 0
10e-6 0
20e-6 12V
40e-6 12V ”…and now high lighted in the my pdf showing the simulation, the content in the ramp.csv file
GL – 73 – Hannes – SM6PGP
10. July 2025 at 4:15 #9005We are getting closer. Here is what I get when going to the Projects tab:
Well that didn’t work! I did a snipping tool copy of the whole screen and it said it put it in the tablet? or wherever Windows 11 copies things to. I did a CTRL-V but nothing happened. So here it is in text.
Projects
CPO
Grok_Twin-T
Twin-t
Test circuit
*****I pick on “Twin-t” and select “Open”.
Content of ‘Twin-t’ | Note
> Schematics
Grok_Twin-T.sch
Twin-t.sch
Verilog
VHDL
Octave
C++ Sources
PCB layouts
> Data Displays
Grok_Twin-T.dpl
> Datasets
Grok_Twin-T.dat
Others
The large area to the right (yellow background) has “untitled” with red background with white X.
Next step? Where do I go to enter the file name “ramp.csv” and enter the information??
Again 73 de WN8P
10. July 2025 at 21:01 #9006OK lets take next step !
You can create your CSV (comma separated value) file in any text editor, Notepad, Notepad++ or in excel name it to whatever…. but extension .csv *(you create this file outside of uSimmics, at least I do it this way)
Now save that csv-file in your project-folder (maybe Grok_prj folder, your project name), thats the folder where you have saved your schematic, Grok_Twin-T.sch
Now in uSimmics, edit your file based voltage source, right click, edit properties, browse and select your .csv file, apply and OK.
Now you should have a file-based voltage source up and running
12. July 2025 at 22:32 #9007I finally got a circuit with transient analysis and ramp source. Here is what I get:
I took a full screen snapshot of circuit and transient analysis with graph. The system stated the snapshot was saved to clipboard, but doing the CTRL-V does nothing.
All I get in my analysis is DC voltages no oscillations.
How do I enter a saved snapshot into this forum? I am using a Windows 11 OS on a laptop PC.
–73 de WN8P, Larry
16. July 2025 at 10:05 #9010So now you have to modify your circuit – maybe not enough gain ?
Try my circuit and check if it oscillates.
73 – Hannes -SM6PGP
