- This topic has 8 replies, 3 voices, and was last updated 1 year, 4 months ago by
Enki.
16. November 2024 at 10:32 #8731
I´m trying to make a design of a combline filter and simulate every stage of the process. However, I can´t make a good simulation using ideal transmission line. In the figure below I show two of the stages:
- Top: filter with impedance inverters implemented with ABCD matrices.
- Bottom: filter with impedance inverter implemented with ideal transmission line.
The filter in the top yields the blue/red traces and the bottom one yields the result in black/green.
I repeated the same simulation in ADS and it works well, so I assume that is a limitation of QucsStudio or I´m doing something wrong. Does anyone knows how to fix this?
17. November 2024 at 19:47 #8732Hi Enki,
What exactly don’t you like about QucsStudio’s results?
18. November 2024 at 18:30 #8733Hi Carsten,
The simulation with series stubs is not accurate, the BW of the filter is too wide. For example, the simulation of both circuits with ADS shows a very similar results, see the figure below.
19. November 2024 at 18:09 #8744Can you post your files?
20. November 2024 at 21:35 #8745Sure, here it is :).
21. November 2024 at 4:29 #8747I can make the bottom wider/over-coupled filter look similar to the top but it requires a lot of changes.
The Z of the 2-port ABCD is very different from the series 57 Ohm tlines.
Do you have the original L/C filter that was used to create these two filters?
21. November 2024 at 21:37 #8748Both filter are actually the same in a different stage of the design.
The one in the bottom is the result of transforming the impedance inverters (2-port ABCD) into a pi network. The series element is a stub and the shunt elements are absorbed by the resonators at both sides. That´s why they resonator stubs are different in both circuits.
Anyway, the filter is well designed, I replicated everything in ADS and the results are what I expected, but not in QucsStudio. So, my conclusion is that I´m using the TL wrongly or the ideal model isn´t correct when it´s in series.
If you are interested in the original LC prototype, you can run the attached schematic.
23. November 2024 at 2:57 #8751Can you explain why the LC lumped filter uses Zin/Zout = 1Ohm? Is this to normalize Zo?
23. November 2024 at 11:00 #8825That´s because the filter is only transformed in frequency but not scaled in impedance. I didn´t do it because at that point I introduce the impedance inverter to make all the resonators shunt as in the first schematic I shared.
If you are interesting in the theory, I started with the method described in the chapter 8.3 in Microwave Engineering. This is Chebyshev filter of order 3 at fc = 1GHz and the LP prototype I used have the following elements:
g0 = g4 = 1
g1 = g3 = 0.8516
g2 = 1.1032
You can also find the table for frequency transformation in Table 8.6.
