Home Forums Usage Unexpected results in uSimmics vs Qucs-S
  • This topic has 4 replies, 2 voices, and was last updated 8 months ago by Hub.
  • #8958
    Hub
      I’m a new QUCS  user with no prior experience with either uSimmics or Qucs-S, and am playing around with both. In a short s-param sim I’m running with some t-lines, with identical (I believe) settings between the two, I’m getting significantly different results and am trying to understand what I might be doing wrong. Any suggestions would be appreciated.  I’ve attached screenshots showing the comparisons, and have also thrown up a quick ADS sim as a comparison of a similar structure for good measure; the Quos-S output is the closest to ADS compared to uSimmics.
      Cheers.
      #8962
      Hub
        Adding in the Qucs-S file since that seems to have exceeded the file size limit.
        #8963
        Hub
          #8964
          SM6PGP
            Hi Hub !
            1. in your uSimmics simulation you have t=0 um in Subst1, change that to some thickness t=35um
            2. you have different widths, lenghts and substrate thickness in your simulations, uSimmics vs ADS, 10 mil = 0.254mm, 1000mil = 25.4 mm, 1550mil = 39.37mm
            3. In your ADS simulation you  have used ML1CTL_C, I think that this is some kind of coupled line model, If I remember the ordinary model is MLIN and MSUB if you wnat to do a comparision with uSimmics.
            /H
            #8967
            Hub
              Hi!
              Thank you so much for the help. The metallization thickness setting helps fix this.
              Though, does this mean that there is a possible default thickness being identified in both ADS and QUCS-S but not in uSimmics? If you see the other screenshots, seems like setting t=0 in the others doesn’t cause the same issue.
              Thanks!
