Home Forums Usage usage stoz function
  • #6780
      I tried qucsStudio today for the first time and I like it.
      I want to plot the impedance loading a signal source. I used to do
      Z_param = stoz(S)
      in Qucs.
      QucsStudio gives
      Error in ‘Eqn4’: Different variable sizes in equation “stoz(S)”.
      The german QucsStudio Help says:
      stoz(Z): transformiert S-Parameter mit Referenzimpedanz Z nach Z-Parameter, Parameter Z ist optional, default ist 50, unterschiedliche Impedanzen sind möglich, z.B. [25, 75]
      So the function does not accept an S matrix as a parameter, but only the impedance?
      Confusingly, this is listed under “Funktionen nur in Schaltungsformeln”. Does this refer to the Gleichung / Equation object?
      #6781
        How do I attach a .sch file to my post? I get an error “Sorry, this file type is not permitted for security reasons.” But others here in the forum seemingly managed to do it.
        #6784
          This old forum post: https://qucsstudio.de/forums/topic/tutorial/
          refers to the “formula” item in the diagrams folder. Is stoz() meant to work with that?
          #6786
            The correct usage of z-parameter transformation is:
            Z_param = stoz()    if your s-parameter ports have 50 ohms
            Z_param = stoz(25)   if your s-parameter ports have 25 ohms
            This works in equation components only, not in diagram equation.
            Anyway, if you want to know the loading of the source, stoz() is not the correct function, because z-parameters are defined with open port terminations.
            rtoz(…) does the job (see attached picture).
            #6790
              Ah, yes. Thank you!
              BTW: For a one port device, rtoz and stoz are the same.
