Home Forums Bug Reports uSimmics 5.8 crashes when selecting Remove within Parameter Tuning
  • #8875
    rebakker
      Within uSimmics 5.8  a [Remove] button is added to ‘Parameter Tuning’. When no components are present in this ‘Parameter Tuning’-window and the [Remove] button is used, uSimmics crashes/terminates.
      Kind regards,
      Rene
      #8880
        You are right, thanks a lot for reporting this bug! It will be fixed in the next release.
        #8932
        n4es
          Parameter tune does not appear to support negative values.
          Negative values are useful as error terms when trying to fit a circuit model to the performance of a physical circuit. i.e.: a negative capacitor in parallel with a capacitor. uSimmics does appear to simulate negative value capacitors correctly.
          Thanks!
          #9118
          Andy_JP
            I confirm.
