Home Forums Bug Reports V422 crashes when simulation is launched from hierarchical schematic
Viewing 6 posts - 1 through 6 (of 6 total)
  • #1032
    Andrea_63
      Good morning,
      I found that v422 crashes if the simulation (i.e. s-parameters or AC) is launched from a schematic that contains blocks with sub circuits. I checked that previous version 332 does not crash.
      Thanks.
      Andrea
      #3047
      ehawker
        I have the same issue but only when the schematic contains a hierarchy of three levels or more, i.e. top level -> subcircuit 1 -> subcirccuit 2.
        It crashes every time when I tries to launch a simulation.
        #3049
          I cannot reproduce this bug. A single subcircuit works as well as a nested one.
          Can you share your examples? Does it always crash? What operation system do you use?
          #3051
          ehawker
            Attached is a simple example to show the crash. If you cannot reproduce it the first time, exit the QucsStudio, launch it again, and open only “top_level.sch” without touching anything else, then click “simulate”. This sequence crashes every time on me. I use Windows 10 but I doubt it matters.
            • This reply was modified 3 years, 9 months ago by ehawker.
            #3056
              Thanks a lot for the example! I can reproduce the bug and will fix it.
              Workaround: Open the subcircuit schematic before the simulation starts, i.e. select the subcircuit component and press “CTRL+i”.
              #3059
              ehawker
                Thank you for looking into this. Yes, I am quite aware of the workaround but as a perfectionist, I would just stay with an older version for now. And hopefully this will be fixed in the next release.
