Home › Forums › Bug Reports › Voltage of labeled node (node.V) not recognized in equation This topic has 1 reply, 2 voices, and was last updated 1 year, 6 months ago by QucsStudio. Viewing 2 posts - 1 through 2 (of 2 total) Author Posts 27. September 2022 at 11:53 #5500 zhuParticipant Unfortunately the bug reported 8-July-2021 using v4.2.2 has not been fixed. The voltage of a labeled node (say VCE.V) can be used in plots, appears in a Table but it is not recognized by Equations. Attachments:Run_v3.2.2.pngError_v4.3.1.pngBugreport_4.2.2.png label_431.txt 3. October 2022 at 8:48 #6162 QucsStudioKeymaster Yes, you’re right. This is still on the ToDo list, because it’s more complicated. I think it will not be fixed before version 5. Author Posts Viewing 2 posts - 1 through 2 (of 2 total) You must be logged in to reply to this topic.
