Home › Forums › Usage › Bandpass filter with tuned transformers
  • #9307
    paul002
      I try to simulate a 4th order chebycev bandpass fiter. The filter has 4 tank circuit a center frequency of 3.6 Mhz and bandwith of 800 Khz. I design the filter in Elsie and the  Rp of the filter is about 390 Ohm. To match to 50 ophms I use the input and output inductor as a transformer.
      The filter s11 and s21 response on 390 ohm is matching the design, however the resonse with the transormers is not matching.    The coupling factor of the transormers is 0.9 and resistance set to 0.
      The transformer turn ratio is 2.79 => 4.7uH / (2.79)2 = 7.7
      Am I making some mistake ? I get the same result if I use an auto transformer.
      bpf simulation
      #9308
      paul002
        I forgot, the expected return loss should be about -26 db
        #9309
        paul002
          I think I found the issue myself. Swapped two values. Now get better result
          sim
