Home › Forums › Usage › Cannot find a .qucs project file with “Create Project”
  • #8646
    “Create project” in the Project pull-down module doesn’t appear to produce any .qucs compressed project files in the ,qucs directory or anywhere else?  Does anyone know where this file is located after executing “Create Project” for a previously generated project folder source directory?
    Thanks…
    #8647
      Do you mean “create package”?
      If you select that, you are asked to give a directory/filename for the package / .qucs file.
