While working with impedance matching (and many other applications), it is very useful to have constant-Q lines in the Smith Chart to guide the design. I managed to draw one for a single value of Q using some tricks as you can see in the figure below. However, it dos not work for a Q sweep, since problems occur with wrong matrix dimensions.
It would be very useful if this feature could be chosen from the Smith Chart configuration window.
Thanks
PU5FRS
This topic was modified 1 year, 10 months ago by
