Home › Forums › Development › Default locations of the files/libraries
- This topic has 5 replies, 3 voices, and was last updated 5 years ago by
tomhajjar.
1. December 2020 at 17:36 #678
It would be helpful to be able to change the default locations of the files/libraries. It was an option on the original Qucs.
1. February 2021 at 20:51 #707This is a big one for me !, I don’t understand why this would be removed as being able to choose where data files are located is fundamental to using a good app, & QucsStudio is a very good app.
I don’t store my data files on the root C: drive, D: is for all my data, makes backup a breeze , if I get a drive full the OS is still happy. I don’t have data cluttering up my boot partition image backups.
Please reinstate the data home folder select option, it will be immensely appreciated.
Regards
This reply was modified 1 year, 9 months ago by
3. February 2021 at 14:41 #722This is possible. Please read the program help (F1 key) or the following thread on this forum:
https://qucsstudio.de/forums/topic/change-directory-where-the-projects-are-saved/
3. February 2021 at 15:59 #724I’m having trouble getting this to work. I have both versions of QucsStudio in separate folders as well as Qucs.
C:\QucsStudio – 2.5.7
C:\QucsStudio – 3.3.2
2.5.7 only gave a warning about incompatible libraries in “user_lib”. 3.3.2 won’t load it’s “built-in” libraries like Z-Diodes nor User libraries due to finding “other” incompatible libraries in “C:\Users\Tom Hajjar\.qucs\user_lib”
My goal is to put QucsStudio User files in a new folder “C:\Users\Tom Hajjar\.qucsstudio” to segregate QucsStudio from Qucs.
Unfortunately I haven’t figured out what QucsStudio shortcut property changes that work.
3. February 2021 at 17:03 #726I created the following folder and put some test projects and an empty user_lib folder.
Using a Dos prompt I get the following results:
3. February 2021 at 20:39 #731Finally got it working. Needed to accurately follow your instructions…
qucs.exe -”c:\Users\Tom Hajjar\.qucsstudio”
