Home › Forums › Bug Reports › Doesn’t check screen exists at start-up
  • #8899
    ChrisWatts
      I use uSimmics on a laptop that sometimes has a second screen connected. If uSimmics is shut down while using the second screen it remembers this configuration. If uSimmics is started with the second screen not present, it still uses this screen location making the window unviewable. The software should check if the screen exists, and if it doesn’t relocate to the screen that does exist.
