Home Forums Bug Reports equation block auto-renaming variable
  • #7126
      add equation block and add a variable a = 1. Apply. Ok.
      Now you should have y=1 and a=1.
      open it again, delete a. Apply. ok.
      open it again. Add. enter name ‘b’. enter value ‘2’. Apply.
      name is now automatically change to ‘a’ , which it should not.
      • This topic was modified 2 years, 8 months ago by Carsten.
      #7132
        I cannot reproduce it!? When exactly does it happen?
        “Ok” is enough, “Apply” is not needed.
        Should have or do you have it?
        Again “Apply” is not necessary.
        So you change ‘y’ to ‘b’ and ‘1’ to ‘2’ and then press “Apply” and not “ok”?
        You mean you are still in the dialog and the ‘b’ in the line-edit field is changed to ‘a’?
        Thanks!
        #7133
          I have. All ok here so far.
          No. Add creates a new line. Add name ‘b’ and value ‘2’ in the empty line.
          yes. As soon as I hit apply.
          I just confirmed it unter Win10.
          #7143
            Yes, you are right, I can confirm it now.
            Many thanks for the report!
