Home › Forums › Bug Reports › freq2time shows error in graph Tagged: Diagram Time_Domain This topic has 1 reply, 2 voices, and was last updated 3 weeks, 3 days ago by MarioK. Viewing 2 posts - 1 through 2 (of 2 total) Author Posts 20. August 2026 at 12:59 #9271 el-spec_SBParticipant uSimmics 5.9 I simulate a coax cable in the frequency range 10 MHz to 20 GHz with 10 MHz steps. The S-parameter looks good. If I plot the time domain signal according to the minimal description I get the error on the diagram. Have I done something wrong, or is this a bug? Attachments:Projekt_-Leitung_TD_FD.jpgDiagramms-editieren.jpg 5. November 2026 at 14:29 #9299 MarioKParticipant Hi el-spec_SB, freq2time appears to require the DC point. If you start the sweep at zero Hz, it should work as intended. Author Posts Viewing 2 posts - 1 through 2 (of 2 total) You must be logged in to reply to this topic.
