Home Forums Development Functions to having easier access to vector and matrix
  • #2996
    pu5frs
      Sometimes it is not possible to have access to simulated data when they are multidimensional.
      It would be very nice if a few functions to manipulate (extract) data from matrix were added. So we could use chained sweeps for interesting simulations.
      Thanks
      PU5FRS
      #3002
        The most common functions are already available. So, if you think that very important ones are missing, please give a concrete example.
        #3033
        pu5frs
          Thank your for replying.
          1. Useful functions could let us to access element ranges of variables. For instance, I can access S[1,1], but cannot access S[1,:]  (all points of line 1),  or S[5:100,1] (points of col 1  belonging to lines 5-100.
          2. Another useful function could let us work better  with data from sweeps. See the example below using HB simulation:
          I will give you an example below
          example
          • This reply was modified 1 year, 11 months ago by maelh. Reason: Convert all remaining http links to https links
          #3037
            These things should already work using the yvalue(…) and range(…) functions. Please see examples on this website.
