Home › Forums › General things › How to use uSimnics.exe from the command line in QucsStudio 5.8? (.vsm file?)
  • #8968
    kawashima
      I am currently using QucsStudio 5.8 and I would like to run uSimnics.exe from the command line.
      In previous versions, it seemed that .vsm files were used as input for uSimnics, but in version 5.8, I cannot find any .vsm files being generated.
      I have a few questions:
      What is the correct input file format for uSimnics.exe in QucsStudio 5.8?
      Is .vsm still used, or has the workflow changed?
      How can I run uSimnics.exe from the command line in this version?
      Could you provide an example command?
      Is there any official documentation or guide for command-line usage of uSimnics.exe in QucsStudio 5.8?
      I would appreciate any clarification on how to properly execute simulations with uSimnics.exe via the command line in the latest version.
      Thank you for your support!
