Home › Forums › Bug Reports › issues with polar function
  • #8680
    Simon_GEII_Bordeaux
      There is an issue with the polar function in the equation component, it seems that the angle is not correctly processed. See example below: red point on the graph is wrong (as well as the equation diagram)
      polar function
      Very interestingly, there won’t be any problem if the equation component is defined WITHOUT  running simulate F2
      #8683
        You are right, I can confirm this bug. Thanks a lot for reporting it! It will be fixed in the coming release.
        #8692
          Hey Michael,
          I’m curious. When can we expect the next release?
          Cheers
