Home Forums Development multiple (parallel) simulations on one sheet
  • #8154
      I can already place an parameter sweep together with an e.g. S-Param simulation on one sheet.
      I would like to have S-Param-simulation and AC simulation next to each other. They would be hierarchy-wise on the same level.
      The old qucs could do that. The results would just be placed together in one dataset.
      e.g. in some of my simulations, I want to calculate voltages and S-Parameters. As QucsStudio is now, I have to disable one of the simulations at a time. unfortunately, this also makes several of my formulas invalid, so I have to enable/disable several formula blocks each time.
      #8156
        Could you provide an example?
        #8157
          here’s an example:
          I have to disable these equations in order to start the p-param simulation.
          The simulation calculates power waves a and b out of voltage probes. In ADS its called “wave probes”, as far as I know.
          #8163
          tomhajjar
            An old Qucs example calculated s-parameters using AC analysis
            #8164
            tomhajjar
              Sending file again….
