Home › Forums › Bug Reports › PCB layouter does not open
  • #9247
    ScottH
      Hi there,
      I am unable to run the ‘PCB Layouter’, either thru the Tools menu or via ctrl-9.
      Expected: pcb program loads.
      Actual: nothing.
      I have tried restarting the program and have created a couple of new projects; whether blank, with discrete bandpass components, or microstrip I cannot get the thing to run.
      I am able to run other tools such as Create EM layout and I can run openEMS simulations.
      I have noticed that if I have a microstrip schematic I can use “‘Transfer to PCB Layouter’ / Shift-F10” to move to the EM layout, but I am unable to export gerbers from there. A discrete schematic does not do anything if I use “‘Transfer to PCB Layouter’ / Shift-F10”.
      uSimmics 5.9, windows 11, 25H2, 26200.8246 “Windows Feature Experience Pack 1000.26100.297.0”, AMD Ryzen 9 3900X, 32gb.
      #9249
      ScottK
        Hey Scott, I am also Scott.
        Anyways I had a similar issue last night and came across this post. I think I found your fix.
        Since you are using uSimmics 5.9, you need to download the uSimmics 5.8 version.
        This 5.8 version contains a file that seems to be missing from uSimmics 5.9 bin in which it.e.cad needs to open.
        file name: QtOpenGL4.dll
        I simply copied and pasted this file into my uSimmics 5.9 bin folder and then it.e.cad started to work.
        I hope this works!
        Best of Luck,
        SK
        #9250
          Thanks a lot for the report! I’ve just renewed the ZIP archive for uSimmics 5.9. It now includes the missing QtOpenGL4.dll file. So, everything should be fine again.
