Home › Forums › Usage › Pout vs Pin sweep in HB
  • #9270
    Thomas
      Hello
      Is there a way to sweep the input power and measure the Pout, to get the classical compression point plot, running HB?
      I have the problem that I don’t know if I can plot the x-axis as power (and not frequency). I tried using a voltage source where the voltage was a function of Pin, and then in the sweep block sweep the power and many other ways but have not been able to figure this out. This is a quite common RF simulation so if there is any example, it would be appreciated.
