Home › Forums › Usage › QucsStudio Library .lib File Format?
  • #8688
    magnus
      Does there exist some documentation on the file format used to create libraries?
      I got some hints by generating a library in QucsStudio
      Project -> Create User Library …
      Apparently, the model definition of a component {COMP} in library {LIBRARY} is prefixed by L{LIBRARY}_{COMP}; interestingly the prefix L is added in the name of the model definition. Any suggestions where to learn about all this syntactic sugar 😉
      <QucsStudio Library 4.3.1 “{LIBRARY}”>
      <Component {COMP}>
      <Model>
      .Def:L{LIBRARY}_{COMP} …
      .Def:End
      </Model>
      </Model>
      </Component>
      Thanks,
      Magnus
