Home Forums Tools RF-Energy Harvester Optimization
  • #786
    migi07
      i’m trying to create an impedance match for an RF rectifier at 0.868 and 2.44 GHz.
      In the first step, I adapted the simulation so that the simulation and measurement match.
      In the second step, I calculated the T-section impedance matching.
      In the third step, I inserted the calculated values in Qucsstudio, simulated and tuned them.
      I would like to get better results with the optimization simulation.My problem is that the simulation only ever adjusts one of the two frequencies.
      My equations(goals):
      pass1 = min(range(S[1,1], 1.885 Ghz, 1.995 GHz))
      pass2 = min(range(S[1,1], 2.40 Ghz, 2.45 GHz))
      both with weight 1 and minimize
      Optimization settings:
      Method: grid search
      Number of restarts: 1
      Variables:
      lengths and widths of all lines in the T-section matching network
      I hope one of you has a tip for me.
      best regards
      Miguel
      • This topic was modified 2 years, 4 months ago by QucsStudio.
      • This topic was modified 1 year, 10 months ago by maelh. Reason: Convert all remaining http links to https links
