Home Forums Installation Run in Linux under Wine
  • #930
    alexpacini
      thanks for all the nice work.
      I am trying to run Qucs Studio under Wine in Linux (OpenSuse tumbleweed) and it generally works ok apart from two cases: Octave post processing and C compiling.
      I am using the example on the website.
      For Octave, I am running ‘Simulation_Octave’ and then one of the schematics inside.
      What I get is the following:
      The simulator is stuck at this stage, nothing is being run.
      I tried running octave from cli using wine, but I don’t get any octave cli.
      The other issue on C compiling is based on the ‘ProgrammingC++’ project.
      Here, I am trying to run the hello.c
      Here the error seems related to the libraries or headers.
      Is there any solution to those errors?
      Thanks, Alex
      • This topic was modified 2 years, 4 months ago by QucsStudio.
      • This topic was modified 1 year, 10 months ago by maelh. Reason: Convert all remaining http links to https links
