Home › Forums › Usage › S Parameter De-embedding
  • #9242
    srmeister
      im trying to de-embed a fixture to measure a component on it, so i recorded 2 S2P files. One without the part, and the other includes the part.
      Now in uSimmics there is option in S2P block to “deembed” but it does not seem to work. I arranged the first recording and the second one in series, using AC Power sources on both ends. Still it will not show any results.
      I could not find any documentation on this matter, neither in QUCS nor in uSimmics.
      Is this feature broken or am i doing something wrong here?
      I used NanoVNA to record the data. Maybe it does not work because the second port is only passive port?
